Ir para o conteúdo principal
Shark NV352 Roller Brush Replacement
O que você precisa
  1. Shark NV352 Roller Brush Replacement, Roller Brush: passo 1, imagem 1 %32 Shark NV352 Roller Brush Replacement, Roller Brush: passo 1, imagem 2 %32
    • Lift the latches on both sides of the vacuum to release the dust canister.
    • Remove the dust canister from the vacuum by lifting it up.
  2. Shark NV352 Roller Brush Replacement: passo 2, imagem 1 %32
    • Lay down the vacuum to access the bottom panel of the roller brush compartment.
  3. Shark NV352 Roller Brush Replacement: passo 3, imagem 1 %32 Shark NV352 Roller Brush Replacement: passo 3, imagem 2 %32
    • Using the metal spudger, pry the two small wheels located at the two bottom corners of the vacuum to remove them.
  4. Shark NV352 Roller Brush Replacement: passo 4, imagem 1 %32 Shark NV352 Roller Brush Replacement: passo 4, imagem 2 %32
    • Remove the eight 19mm Phillips #2 screws from the plastic cover.
    • Remove the two 14 mm Phillips #2 screws from the upper section of the plastic cover.
  5. Shark NV352 Roller Brush Replacement: passo 5, imagem 1 %32 Shark NV352 Roller Brush Replacement: passo 5, imagem 2 %32
    • You will need to apply a strong force while pulling the wheels off because they are attached very tightly.
    • Remove the wheels by pulling them out of their axles, away from the vacuum.
  6. Shark NV352 Roller Brush Replacement: passo 6, imagem 1 %32 Shark NV352 Roller Brush Replacement: passo 6, imagem 2 %32
    • Perform the next step slowly and carefully so the wiring connecting the motherboard to the rest of the vacuum is not broken.
    • Gently pull the grey lower part of the roller brush compartment away from the purple upper part of the compartment.
  7. Shark NV352 Roller Brush Replacement: passo 7, imagem 1 %32
    • Lift up and then pull the roller belt off of the roller brush and the motor to remove it.
  8. Shark NV352 Roller Brush Replacement: passo 8, imagem 1 %32
    • Take out the roller brush by lifting it out of its tray.
Conclusão
9 outras pessoas executaram este guia.
Amy Moran
Membro desde: 09/22/17
603 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S18-G5, Forte Fall 2017 Membro de Cal Poly, Team S18-G5, Forte Fall 2017
CPSU-FORTE-F17S18G5
Membros da 4
Autoria de 10 guias
Um comentário
FOR SOME MODELS - THE BRUSH WILL NOT OPERATE IN AN UPRIGHT POSITION.
Shark navigator 350-353 series - if you have cleaned the roller and it doesn't work, TILT THE HANDLE BACK then try.
elaina heinz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 82
Duração total: 4,800
