Ir para o conteúdo principal
Shark NV352 Filter Replacement
  1. Shark NV352 Filter Replacement, Filter: passo 1, imagem 1 %32
    • Ensure that you are removing the filters from the vacuum in an area that you don't mind getting dirty because the filters will be very dusty.
    • Lift the latches on both sides of the vacuum to release the dust canister.
  2. Shark NV352 Filter Replacement: passo 2, imagem 1 %32 Shark NV352 Filter Replacement: passo 2, imagem 2 %32
    • Tilt the dust canister forward to release it from its position.
    • Carefully lift away the dust canister and set it aside.
  3. Shark NV352 Filter Replacement: passo 3, imagem 1 %32 Shark NV352 Filter Replacement: passo 3, imagem 2 %32 Shark NV352 Filter Replacement: passo 3, imagem 3 %32
    • Remove the upper filter by lifting upwards on it.
    • Now that the lower filter is exposed, remove it by pulling it upwards.
Conclusão
4 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S18-G5, Forte Fall 2017 Membro de Cal Poly, Team S18-G5, Forte Fall 2017
CPSU-FORTE-F17S18G5
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 20
Duração total: 966
