Ir para o conteúdo principal
Shark Lift-Away Professional Steam Pocket Mop Pad Replacement
  1. Shark Lift-Away Professional Steam Pocket Mop Pad  Replacement, Mop Pad: passo 1, imagem 1 %32 Shark Lift-Away Professional Steam Pocket Mop Pad  Replacement, Mop Pad: passo 1, imagem 2 %32
    • Turn off the Steam Pocket Mop and unplug it from the wall.
    • Be sure that any water in the water tank cools before proceeding.
  2. Shark Lift-Away Professional Steam Pocket Mop Pad  Replacement: passo 2, imagem 1 %32 Shark Lift-Away Professional Steam Pocket Mop Pad  Replacement: passo 2, imagem 2 %32 Shark Lift-Away Professional Steam Pocket Mop Pad  Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Microfiber Cleaning Cloths
    $3.99
    Comprar
    • Release the quick fasteners from the top of the cloth using the loops.
    • Slide the cloth off from around the mop head.
    • Our mop pad was missing, so we used a similar microfiber cloth in our images.
Conclusão
Repeat this process every time you need to replace your mop pad.
Rachel Howe
Membro desde: 10/17/18
261 Reputação
Autoria de 2 guias
Equipe
UW Tacoma, Team S1-G3, Rose Fall 2018 Membro de UW Tacoma, Team S1-G3, Rose Fall 2018
UWT-ROSE-F18S1G3
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 19
Duração total: 1,324
