Ir para o conteúdo principal
Shark Lift-Away Professional Steam Pocket Mop Handle Replacement
O que você precisa
  1. Shark Lift-Away Professional Steam Pocket Mop Handle Replacement, Mop Handle: passo 1, imagem 1 %32
    • Turn off the Steam Pocket Mop and unplug it from the wall.
    • Be sure that any water in the water tank cools before proceeding.
  2. Shark Lift-Away Professional Steam Pocket Mop Handle Replacement: passo 2, imagem 1 %32
    • Place the Steam Pocket Mop face down on a flat surface.
    • Take note of the placement of the handle; the side labelled "front" should should face forward.
  3. Shark Lift-Away Professional Steam Pocket Mop Handle Replacement: passo 3, imagem 1 %32 Shark Lift-Away Professional Steam Pocket Mop Handle Replacement: passo 3, imagem 2 %32 Shark Lift-Away Professional Steam Pocket Mop Handle Replacement: passo 3, imagem 3 %32
    • Remove the screw located underneath the cord holder.
    • Turn the screwdriver counter-clockwise to loosen the screw from its slot.
    • This is a long screw and will take time to remove.
Conclusão
To disassemble your device, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
Nancy K Do
Membro desde: 10/17/18
165 Reputação
Autoria de 1 guia
Equipe
UW Tacoma, Team S1-G3, Rose Fall 2018 Membro de UW Tacoma, Team S1-G3, Rose Fall 2018
UWT-ROSE-F18S1G3
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 37
Duração total: 6,249
