Ir para o conteúdo principal
Shark Lift-Away Professional Steam Pocket Mop Accessory Hose Attachment Replacement
  1. Shark Lift-Away Professional Steam Pocket Mop Accessory Hose Attachment  Replacement, Accessory Hose Attachment: passo 1, imagem 1 %32 Shark Lift-Away Professional Steam Pocket Mop Accessory Hose Attachment  Replacement, Accessory Hose Attachment: passo 1, imagem 2 %32
    • Turn off the Steam Pocket Mop and unplug it from the wall.
    • Be sure that any water in the water tank cools before proceeding.
  2. Shark Lift-Away Professional Steam Pocket Mop Accessory Hose Attachment  Replacement: passo 2, imagem 1 %32 Shark Lift-Away Professional Steam Pocket Mop Accessory Hose Attachment  Replacement: passo 2, imagem 2 %32
    • Disconnect the hand-held steamer unit from the accessory extension hose.
    • Grip the hand-held steamer and push down on the two release buttons.
    • Gently pull the accessory extension hose out in a horizontal motion until it disconnects.
    • When reassembling, be sure to insert the base of the hand-held unit first.
    • If you have any problems with the hand-held steamer locking into place, please consult our Troubleshooting Page.
    • While the accessory extension hose is not pictured here, the procedure is the same.
Conclusão
Rachel Howe
Membro desde: 10/17/18
261 Reputação
Autoria de 2 guias
Equipe
UW Tacoma, Team S1-G3, Rose Fall 2018 Membro de UW Tacoma, Team S1-G3, Rose Fall 2018
UWT-ROSE-F18S1G3
Membros da 4
Autoria de 10 guias
2 comentários
What if it won't allow to power on once reassembled? The light flashes but won't click on.
Aubrey Diaz - Responder
really?? take it on and off with more words.... how about something helpful like where this stupid little rubber band goes so that the trigger is actuated when the unit is placed in the floor mopper. pat yourself on the back you rewrote the basic user instructions and called it a repair. thanks for the complete waste of my time
Jessica Mcallister - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 30
Duração total: 2,563
