Ir para o conteúdo principal
Shark IQ AV993 Wheels Replacement
O que você precisa
  1. Shark IQ AV993 Wheels Replacement, Battery: passo 1, imagem 1 %32
    • Unscrew the two 14 mm screws on the battery panel using a Phillips #1 screwdriver.
  2. Shark IQ AV993 Wheels Replacement: passo 2, imagem 1 %32
    • Gently pull the white tabs on the battery straight upward.
    • There is a clip inserted into a plastic housing via wiring. Disconnect the battery by pressing in the clip.
    • Don't pull up on the battery too hard as a wire connects to the robot. Don't want to damage the wire here.
    • Remove the battery from the device.
  3. Shark IQ AV993 Wheels Replacement, Bumper: passo 3, imagem 1 %32 Shark IQ AV993 Wheels Replacement, Bumper: passo 3, imagem 2 %32
    • Remove the five 10 mm screws from the bottom of the device using a T15 Torx screwdriver.
  4. Shark IQ AV993 Wheels Replacement: passo 4, imagem 1 %32
    • Pry both ends of the black piece to snap it out of place.
  5. Shark IQ AV993 Wheels Replacement: passo 5, imagem 1 %32
    • Use both hands to lift the device.
    • The front bumper that is seated on the device will fall off.
    • This is completely normal, as the screws and the bottom holder are the only things holding the bumper in place.
  6. Shark IQ AV993 Wheels Replacement, Wheels: passo 6, imagem 1 %32 Shark IQ AV993 Wheels Replacement, Wheels: passo 6, imagem 2 %32
    • Flip over the vacuum so that the bottom is facing upwards.
    • Remove the five 14 mm screws using a T20 Torx screwdriver.
  7. Shark IQ AV993 Wheels Replacement: passo 7, imagem 1 %32
    • Pull upward on the wheel to remove the wheel housing.
    • Carefully remove this as there is a clip connecting to the wheel.
    • Press the tab on the clip and slide the wires out of the housing.
    • Repeat this step and the previous step for the other wheel assembly.
Conclusão
Uma outra pessoa concluiu este guia.
Marc Farah
Membro desde: 10/26/22
94 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 3-3, Botvin Fall 2022 Membro de UMass Dartmouth, Team 3-3, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G3
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 247
