Ir para o conteúdo principal
Shark IQ AV993 Bumper Replacement
O que você precisa
  1. Shark IQ AV993 Bumper Replacement, Battery: passo 1, imagem 1 %32
    • Unscrew the two 14 mm screws on the battery panel using a Phillips #1 screwdriver.
  2. Shark IQ AV993 Bumper Replacement: passo 2, imagem 1 %32
    • Gently pull the white tabs on the battery straight upward.
    • There is a clip inserted into a plastic housing via wiring. Disconnect the battery by pressing in the clip.
    • Don't pull up on the battery too hard as a wire connects to the robot. Don't want to damage the wire here.
    • Remove the battery from the device.
  3. Shark IQ AV993 Bumper Replacement, Bumper: passo 3, imagem 1 %32 Shark IQ AV993 Bumper Replacement, Bumper: passo 3, imagem 2 %32
    • Remove the five 10 mm screws from the bottom of the device using a T15 Torx screwdriver.
  4. Shark IQ AV993 Bumper Replacement: passo 4, imagem 1 %32
    • Pry both ends of the black piece to snap it out of place.
  5. Shark IQ AV993 Bumper Replacement: passo 5, imagem 1 %32
    • Use both hands to lift the device.
    • The front bumper that is seated on the device will fall off.
    • This is completely normal, as the screws and the bottom holder are the only things holding the bumper in place.
Conclusão
Kyle Rhines
Membro desde: 10/26/22
558 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 3-3, Botvin Fall 2022 Membro de UMass Dartmouth, Team 3-3, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G3
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 47
Duração total: 880
