Ir para o conteúdo principal
Shark IONFlex 2X Wheel Replacement
  1. Shark IONFlex 2X Wheel Replacement, Wheel: passo 1, imagem 1 %32
    • Grab the wheel at the edges.
  2. Shark IONFlex 2X Wheel Replacement: passo 2, imagem 1 %32 Shark IONFlex 2X Wheel Replacement: passo 2, imagem 2 %32
    • Pull the wheel away from the floor unit base with a strong pull.
    • Repeat steps for the other side.
Conclusão
3Comentários do guia
Great, now to actually find replacement wheels :/
Robert Roy - Responder
Any idea where I can purchase a replacement wheel?
Hyrum Borrego - Responder
There is a vacuum tube between the wheels, will removing the wheels get me access to the tube, there is a hole in the tubing,thus crud escapes into the air. If there's a way to repair this i would love to know how. Great vacuum, crap for construction quality and the tools required to remove the base plate are not standard household tools. Any ideas would be kindly appreciated. Thank you
Kaci Celeste Reyes Roberts - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Ao todo: 1,664
