Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide will show you how to replace the two filters on the top of the motor unit of the Shark IONFlex 2X.
With normal usage, the filters will not need to be replaced, but will need to be rinsed and air dried for 24 hours prior to re-insertion in the machine once every month.
Squeeze the lever labeled “Clean Filters Monthly” and pull up on the plastic cover.
