Ir para o conteúdo principal
Shark IONFlex 2X Soft Brush Roll Replacement
  1. Shark IONFlex 2X Soft Brush Roll Replacement, Soft Brush Roll: passo 1, imagem 1 %32
    • Press and slide the access brush roll buttons towards the "Access Brush Roll" printing on casing.
  2. Shark IONFlex 2X Soft Brush Roll Replacement: passo 2, imagem 1 %32
    • Lift plastic casing upward and off of the top of the floor unit. Place off to the side.
  3. Shark IONFlex 2X Soft Brush Roll Replacement: passo 3, imagem 1 %32
    • Pull the red Pull tab that is located on the right side of the soft brush roll away from the front of the vacuum and place the soft brush roll to the side.
Conclusão
Um comentário
I’m trying to fix the plastic gear that the roller fits onto. It’s broken and I think it needs to be disassembled more and need replacement parts. Model # IF200W. Any advice??
Anthony - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 19
Duração total: 2,670
