Ir para o conteúdo principal
Shark ION Robot S87 Bumper Replacement
O que você precisa
  1. Shark ION Robot S87 Bumper Replacement, Bumper: passo 1, imagem 1 %32
    • Flip the Shark ION Robot S87 on its underside so that the bumper and its screws are facing upwards.
    • Use a Hex 2mm screwdriver to remove the five 8mm screws from the bumper.
  2. Shark ION Robot S87 Bumper Replacement: passo 2, imagem 1 %32 Shark ION Robot S87 Bumper Replacement: passo 2, imagem 2 %32 Shark ION Robot S87 Bumper Replacement: passo 2, imagem 3 %32
    • Once all screws have been removed lift the thin side of the bumper upwards to remove it from the robot.
    • Lift the robot up so that the larger part of the bumper stays on the floor and is removed.
    • Once both pieces of the bumper have been removed, you can place the robot back down.
  3. Shark ION Robot S87 Bumper Replacement: passo 3, imagem 1 %32
    • Check all sensors and remove any that may have debris in front of it.
    • You may also swap out the bumper for another depending on whether or not it is broken.
Conclusão
Adeel Ahmad
Membro desde: 01/14/20
256 Reputação
Autoria de 2 guias
Equipe
Um comentário
Where can I buy a new bumper?
Lacy - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 18
Últimos 30 dias: 99
Ao todo: 12,841
