Ir para o conteúdo principal
Shark ION Robot R75 Side Brush Replacement
O que você precisa
  1. Shark ION Robot R75 Side Brush Replacement, Side Brush: passo 1, imagem 1 %32 Shark ION Robot R75 Side Brush Replacement, Side Brush: passo 1, imagem 2 %32 Shark ION Robot R75 Side Brush Replacement, Side Brush: passo 1, imagem 3 %32
    • Grab the side brushes by the plastic tab at the base of the bristles, and gently lift up.
    • It's recommended to clean the area with a dry microfiber cloth during replacement, as debris can collect beneath the brush during use.
Conclusão
2 comentários
I have removed/lost my screw that went inside the side brush. Do you have screw size recommendation to replace it? Shark doesn't sell them and says the brush may fall off if I don't have my screw. Is it guaranteed that Phillips #1 Screwdriver would be able to remove screws? I have tried all types of screwdrivers and haven't found one to remove the other screw to take it to the store to find the right size to replace what I am missing.
Kell S - Responder
Our Shark AV1002AE needs a Torx T-9 to remove the screw. However we have not found a replacement screw or insert
Kathy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 31
Últimos 30 dias: 142
Duração total: 6,398
