Ir para o conteúdo principal
Shark ION Robot R75 Caster Wheel Replacement
O que você precisa
  1. Shark ION Robot R75 Caster Wheel Replacement, Shark ION Robot R75 Caster Wheel: passo 1, imagem 1 %32
    • Orient the device with the bottom facing up.
  2. Shark ION Robot R75 Caster Wheel Replacement: passo 2, imagem 1 %32 Shark ION Robot R75 Caster Wheel Replacement: passo 2, imagem 2 %32 Shark ION Robot R75 Caster Wheel Replacement: passo 2, imagem 3 %32
    • Using a plastic opening tool, pry first one side of the wheel, then the other out of the caster.
    • Remove the wheel.
  3. Shark ION Robot R75 Caster Wheel Replacement: passo 3, imagem 1 %32 Shark ION Robot R75 Caster Wheel Replacement: passo 3, imagem 2 %32 Shark ION Robot R75 Caster Wheel Replacement: passo 3, imagem 3 %32
    • Using a Torx TR9 screwdriver, remove both screws from the caster assembly beneath the wheel.
    • Pull the caster assembly up from its slot in the device.
Conclusão
Um comentário
Thanks, my compliments to your clear, simple instructions. And I love my shark AV2500 self-emptying machine--but when will manufactures realize small buy normal Philips screwheads doesn't cost more than chump change on a unit but make it A WHOLE LOT EASYER ON THEIR CUTOMERS.
Dennis King - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 30
Últimos 30 dias: 114
Duração total: 4,713
