Ir para o conteúdo principal
Shark ION Robot 750 Button Panel Replacement
O que você precisa
  1. Shark ION Robot 750 Button Panel Replacement, Button Panel: passo 1, imagem 1 %32 Shark ION Robot 750 Button Panel Replacement, Button Panel: passo 1, imagem 2 %32
    • Before you begin, make sure the vacuum is off.
    • Use a spudger to remove the top case of the vacuum.
    • Flip over the top case.
    • Use tweezers or your hands to remove the center button panel from the socket.
  2. Shark ION Robot 750 Button Panel Replacement: passo 2, imagem 1 %32 Shark ION Robot 750 Button Panel Replacement: passo 2, imagem 2 %32
    • Use your hands or tweezers to remove the other button panel from its socket.
    • Use a spudger to pop the panel off of the connector if you need help.
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Ashley Nguyen
Membro desde: 02/08/24
85 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 13
Ao todo: 127
