Ir para o conteúdo principal
Shark ION RV754 Filter Replacement
O que você precisa
  1. Shark ION RV754 Filter Replacement, Dust Filter(s): passo 1, imagem 1 %32
    • Flip the robot vacuum upside down so the wheels are facing up.
    • Press the dust bin removal latch and slide out the dust bin.
    Pergunte ao FixBot
  2. Shark ION RV754 Filter Replacement: passo 2, imagem 1 %32
    • Pull out the blue filter on the inside of the dust tray.
    • This filter is not attached to anything and should come out easily.
    Pergunte ao FixBot
  3. Shark ION RV754 Filter Replacement: passo 3, imagem 1 %32
    • To access the second filter, open the debris tray.
    • Hold the tray with two fingers at the indicated holes, and use your other hand to pull from the opposite side of the tray.
    Pergunte ao FixBot
  4. Shark ION RV754 Filter Replacement: passo 4, imagem 1 %32 Shark ION RV754 Filter Replacement: passo 4, imagem 2 %32 Shark ION RV754 Filter Replacement: passo 4, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the 7.3 mm screw securing the second filter.
    • Lift the filter out from the same side where you removed the screw.
    Pergunte ao FixBot
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 51
Ao todo: 280
