Ir para o conteúdo principal
Shark Flex DuoClean Drive Belt Replacement
O que você precisa
  1. Shark Flex DuoClean Drive Belt Replacement, Garage Door: passo 1, imagem 1 %32 Shark Flex DuoClean Drive Belt Replacement, Garage Door: passo 1, imagem 2 %32
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
  2. Shark Flex DuoClean Drive Belt Replacement, Side Component: passo 2, imagem 1 %32 Shark Flex DuoClean Drive Belt Replacement, Side Component: passo 2, imagem 2 %32
    • Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
  3. Shark Flex DuoClean Drive Belt Replacement: passo 3, imagem 1 %32 Shark Flex DuoClean Drive Belt Replacement: passo 3, imagem 2 %32
    • Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
  4. Shark Flex DuoClean Drive Belt Replacement: passo 4, imagem 1 %32
    • Use the iFixit Opening Tool to pry the side of the vacuum open.
  5. Shark Flex DuoClean Drive Belt Replacement: passo 5, imagem 1 %32
    • Remove the side component with your hands.
  6. Shark Flex DuoClean Drive Belt Replacement, Drive Belt: passo 6, imagem 1 %32 Shark Flex DuoClean Drive Belt Replacement, Drive Belt: passo 6, imagem 2 %32
    • Remove old the belt from the two gears by prying it off using the metal spudger.
    • The new belt will be very tight and difficult to put back on. In order to reinstall, start with the belt on one gear, then slowly rotate the other gear, pushing on the belt and allowing it to catch the teeth.
  7. Shark Flex DuoClean Drive Belt Replacement: passo 7, imagem 1 %32
    • Repeat on the other side of the vacuum.
Conclusão
9 outras pessoas executaram este guia.
Christian Fuller
Membro desde: 10/08/18
420 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S17-G5, White Fall 2018 Membro de Cal Poly, Team S17-G5, White Fall 2018
CPSU-WHITE-F18S17G5
Membros da 4
Autoria de 14 guias
10 comentários
Thanks… Would have taken me forever to figure out how to get to the belts…!!!
Mike Babb - Responder
Wonderful directions and a great help, thanks. However one important factor was left out, the part number for the belts.
Dave Orr - Responder
Where to get the carpet brush belt? What would the belt size be?
Silver Dominator - Responder
Add me to the rest. I also want a belt. Does anybody ever respond to these questions?
I’m hopeful we can find a source
ShellyB
shellyb -
the belt, roller brush, entire floor unit, etc are on amazon
john smith -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 70
Últimos 30 dias: 372
Duração total: 53,614
