Ir para o conteúdo principal
Shark DuoClean Powered Lift-Away Speed Brushroll Replacement
  1. Shark DuoClean Powered Lift-Away Speed Brushroll Replacement, Brushroll: passo 1, imagem 1 %32 Shark DuoClean Powered Lift-Away Speed Brushroll Replacement, Brushroll: passo 1, imagem 2 %32 Shark DuoClean Powered Lift-Away Speed Brushroll Replacement, Brushroll: passo 1, imagem 3 %32
    • Press the two Brush Roll Access buttons down at the same time to detach the cover.
    • Pull the cover off of the vacuum by lifting it up.
  2. Shark DuoClean Powered Lift-Away Speed Brushroll Replacement: passo 2, imagem 1 %32 Shark DuoClean Powered Lift-Away Speed Brushroll Replacement: passo 2, imagem 2 %32
    • Pull up on the Pull Tab to remove the large brush roll.
  3. Shark DuoClean Powered Lift-Away Speed Brushroll Replacement: passo 3, imagem 1 %32 Shark DuoClean Powered Lift-Away Speed Brushroll Replacement: passo 3, imagem 2 %32
    • Press the Eject Roller button to detach the small roller.
    • Pull the roller away from the vacuum to remove it.
Conclusão
Catie Halvorsen
Membro desde: 10/08/18
703 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S17-G4, White Fall 2018 Membro de Cal Poly, Team S17-G4, White Fall 2018
CPSU-WHITE-F18S17G4
Membros da 4
Autoria de 16 guias
Um comentário
I need help with removing the beater bar on the nv835 I can't find help nowhere
Ethel McClintock - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 82
Últimos 30 dias: 355
Duração total: 34,632
