Introdução
If you are having a problem with your device's Front motor, Here is a Step by step guide to replace a faulty or broken Front motor.
O que você precisa
Remove the two 12mm screws from the front face plate with the PH2 bit from the tool kit.
3 outras pessoas executaram este guia.
