Ir para o conteúdo principal
Shark Cordless Pet Perfect Front Belt Replacement
O que você precisa
  1. Shark Cordless Pet Perfect Front Belt Replacement, Front Belt: passo 1, imagem 1 %32 Shark Cordless Pet Perfect Front Belt Replacement, Front Belt: passo 1, imagem 2 %32
    • Remove the two 12mm screws from the front face plate with the PH2 bit from the tool kit.
  2. Shark Cordless Pet Perfect Front Belt Replacement: passo 2, imagem 1 %32 Shark Cordless Pet Perfect Front Belt Replacement: passo 2, imagem 2 %32 Shark Cordless Pet Perfect Front Belt Replacement: passo 2, imagem 3 %32
    • Once the screws are removed pull the front face plate off. This will allow access to the belt and motor.
  3. Shark Cordless Pet Perfect Front Belt Replacement: passo 3, imagem 1 %32 Shark Cordless Pet Perfect Front Belt Replacement: passo 3, imagem 2 %32 Shark Cordless Pet Perfect Front Belt Replacement: passo 3, imagem 3 %32
    • Lift the brush roller upwards towards you, and the brush roller should come out along with the belt.
  4. Shark Cordless Pet Perfect Front Belt Replacement: passo 4, imagem 1 %32 Shark Cordless Pet Perfect Front Belt Replacement: passo 4, imagem 2 %32
    • Remove the belt from the motor mount, and then replace with a new belt.
Conclusão
Ben Dzugen
Membro desde: 02/02/17
383 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 16-2, Blackwell Spring 2017 Membro de USF Tampa, Team 16-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G2
Membros da 4
Autoria de 11 guias
2 comentários
Nice and simple but where can we purchase the belts?
jmrlachance - Responder
My shark pet vacuum didn't come with lint brush roller. How do I get one. I buy these pet vacuum for friends/family. Please respond
Tina Cherney - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 26
Duração total: 2,770
