Ir para o conteúdo principal
Shark Cordless Pet Perfect Battery Replacement
O que você precisa
  1. Shark Cordless Pet Perfect Battery Replacement, Battery: passo 1, imagem 1 %32 Shark Cordless Pet Perfect Battery Replacement, Battery: passo 1, imagem 2 %32 Shark Cordless Pet Perfect Battery Replacement, Battery: passo 1, imagem 3 %32
    • Remove the Dust Cap Container then remove the 7.5mm screw (with the PH2 Bit) from the battery cover.
    • Using a black spudger pry open the cover, and remove the cover plate.
  2. Shark Cordless Pet Perfect Battery Replacement: passo 2, imagem 1 %32 Shark Cordless Pet Perfect Battery Replacement: passo 2, imagem 2 %32
    • Once the battery cover is removed slide the battery mount upwards and pull it out.
  3. Shark Cordless Pet Perfect Battery Replacement: passo 3, imagem 1 %32 Shark Cordless Pet Perfect Battery Replacement: passo 3, imagem 2 %32 Shark Cordless Pet Perfect Battery Replacement: passo 3, imagem 3 %32
    • Pull out the battery and then disconnect the battery at the quick disconnects.
Conclusão
3 outras pessoas executaram este guia.
Ashley Calkins
Membro desde: 02/02/17
560 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 16-2, Blackwell Spring 2017 Membro de USF Tampa, Team 16-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G2
Membros da 4
Autoria de 11 guias
4 comentários
Throw it away and buy new lithium Pet Perfect
John Carson - Responder
I changed the battery, it still shuts off after 1 second
Garry - Responder
It has a 2 year warranty, mine quit working at 2 years 10 months. Pretty expensive for only 34 months.
Ralph E Beaver - Responder
Mine still working after 3 (three)years and it was $45 at the time from Walmart. Wouldn't be cheaper to buy an other whole unit than waste $45 plus tax, plus work just on the battery pack like Amazon's Banshee ( read EXTRATERRESTRIAL ) battery pack of $45 plus tax ???
Aurel Tita - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 23
Últimos 30 dias: 88
Duração total: 14,135
