Introdução
If you are having a problem with your device's Battery, Here is a step by step guide to replace a dead or faulty Battery.
O que você precisa
Remove the Dust Cap Container then remove the 7.5mm screw (with the PH2 Bit) from the battery cover.
Using a black spudger pry open the cover, and remove the cover plate.
3 outras pessoas executaram este guia.
4 comentários
Throw it away and buy new lithium Pet Perfect
It has a 2 year warranty, mine quit working at 2 years 10 months. Pretty expensive for only 34 months.
Mine still working after 3 (three)years and it was $45 at the time from Walmart. Wouldn't be cheaper to buy an other whole unit than waste $45 plus tax, plus work just on the battery pack like Amazon's Banshee ( read EXTRATERRESTRIAL ) battery pack of $45 plus tax ???
