Ir para o conteúdo principal
Shark Clean Sense HP102PET Filter Replacement
  1. Shark Clean Sense HP102PET Filter Replacement, Filter: passo 1, imagem 1 %32 Shark Clean Sense HP102PET Filter Replacement, Filter: passo 1, imagem 2 %32
    • Turn off and unplug the air purifier before beginning
    • Carefully flip the air purifier upside down and twist the bottom cap to the unlocked position.
    • Remove the bottom cap.
  2. Shark Clean Sense HP102PET Filter Replacement: passo 2, imagem 1 %32
    • Pull out the old filter using the removal tabs and discard it.
    • Remove all packaging and wrapping from the new filter.
  3. Shark Clean Sense HP102PET Filter Replacement: passo 3, imagem 1 %32
    • Insert the new filter and replace the filter door. Twist the filter door until it clicks into place.
    • Carefully return the air purifier to the upright position, plug it back in, and turn on the power. Calibration will begin.
  4. Shark Clean Sense HP102PET Filter Replacement: passo 4, imagem 1 %32
    • After installing a new filter, press and hold the Filter Life button on the top control panel for 3 seconds to reset the filter life percentage. The unit will beep when the filter life is reset to 100%.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 57
