Ir para o conteúdo principal
Shank Button Replacement
O que você precisa
  1. Shank Button Replacement, Shank Button: passo 1, imagem 1 %32 Shank Button Replacement, Shank Button: passo 1, imagem 2 %32 Shank Button Replacement, Shank Button: passo 1, imagem 3 %32
    • Remove your loose button (if necessary).
    • If the button is already missing, remove any loose threads from your garment.
    • Mark where the button was on the garment to hold place (a felt tip pen works fine, just keep the marking small)
    Pergunte ao FixBot
    Comentar
  2. Shank Button Replacement: passo 2, imagem 1 %32 Shank Button Replacement: passo 2, imagem 2 %32 Shank Button Replacement: passo 2, imagem 3 %32
    • Measure out your thread. An easy measuring reference is the length of one arm fully extended.
    • Thread your needle.
    • Pull the thread until two equal parts are on either side of the needle.
    • Tie a knot in the end of your thread (both ends should be tied together creating a double thread).
    Pergunte ao FixBot
    Comentar
  3. Shank Button Replacement: passo 3, imagem 1 %32 Shank Button Replacement: passo 3, imagem 2 %32 Shank Button Replacement: passo 3, imagem 3 %32
    • Insert your needle into the marked space where your needle should go on the top side of the garment (that way the button will hide your knot).
    • Pull the thread until the knot rests on the fabric.
    • Insert your needle into the shank on the back of your button.
    • Pull the thread until the button rests on the fabric.
    • Insert the needle back into the same space on your fabric. Repeat the above instructions 5 times or until the button is firmly attached.
    Pergunte ao FixBot
    Comentar
  4. Shank Button Replacement: passo 4, imagem 1 %32 Shank Button Replacement: passo 4, imagem 2 %32 Shank Button Replacement: passo 4, imagem 3 %32
    • To tie off your thread, insert the needle back into the fabric near your previous stitches.
    • Pull thread until there is a small loop (do not pull flush with fabric).
    • Insert the needle into the thread loop and pull through.
    • Pull the thread until the loop closes and a knot is formed.
    Pergunte ao FixBot
    Comentar
  5. Shank Button Replacement: passo 5, imagem 1 %32 Shank Button Replacement: passo 5, imagem 2 %32 Shank Button Replacement: passo 5, imagem 3 %32
    • Trim any excess thread from the button area.
    • Enjoy your newly repaired item!
    Pergunte ao FixBot
    Comentar
Linha de Chegada
Rebekah Kilpatrick
Membro desde: 09/20/23
121 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 64
Ao todo: 1,030
