Ir para o conteúdo principal
Sewing a small Hole for a Seamless Fix
O que você precisa
  1. Sewing a small Hole for a Seamless Fix, Sewing a small Hole for a Seamless Fix: passo 1, imagem 1 %32
    • Ensure the hole is small enough to be easily repaired with sewing.
  2. Sewing a small Hole for a Seamless Fix: passo 2, imagem 1 %32 Sewing a small Hole for a Seamless Fix: passo 2, imagem 2 %32
    • Thread the needle with a length of thread doubling it over at the end to secure it.
    • At a good length (depending on the size of the hole), cut off the excess and tie a knot at the end of the thread.
  3. Sewing a small Hole for a Seamless Fix: passo 3, imagem 1 %32
    • Position the sweater with the hole facing up on a flat surface. Make sure your sweater is inside out.
    • This will make the stitches not as visible.
  4. Sewing a small Hole for a Seamless Fix: passo 4, imagem 1 %32 Sewing a small Hole for a Seamless Fix: passo 4, imagem 2 %32 Sewing a small Hole for a Seamless Fix: passo 4, imagem 3 %32
    • Insert the needle into the fabric slightly above the hole, pulling it through the backside of the sweater, and repeat this process along the edges of the hole to create a series of stitches.
  5. Sewing a small Hole for a Seamless Fix: passo 5, imagem 1 %32
    • Continue stitching back and forth across the hole in a zig-zag pattern until it is completely closed, ensuring stitches are tight and secure.
  6. Sewing a small Hole for a Seamless Fix: passo 6, imagem 1 %32 Sewing a small Hole for a Seamless Fix: passo 6, imagem 2 %32
    • Tie off the thread by creating a small knot at the end of the stitching and trimming any excess thread with scissors.
  7. Sewing a small Hole for a Seamless Fix: passo 7, imagem 1 %32
    • Reverse your sweater outside in. Tug at the area slightly to ensure the stitches hold and the fabric remains intact.
Linha de Chegada
Kendra Tejada
Membro desde: 04/22/24
145 Reputação
Autoria de 1 guia
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 12
Ao todo: 146
