Introdução
A ladder stitch, or closure stitch, is a sewing technique that allows you to close a tear without leaving the stitching visible.
The trick is to make the stitches as small and as even as possible. This technique works for repairing almost any type of tear.
O que você precisa
Thread your needle and tie a knot in the end.
Drive the needle from the back of the material, just before where the tear starts.
Pull the thread taut.
One the last stitch, drive the needle through both sides of the fabric, taking as small of a stitch as possible.
Slowly pull the thread. As you pull, a loop will form. Draw the needle through this loop, and pull the thread taut.
Repeat this step, taking a tiny stitch, drawing the needle through the loop, and pulling taut.
Ensure that the stitches are tight, and cut any excess threads.
Instead of cutting the excess thread, I leave enough length at the end to “bury” the long threads inside the repair, where they will not show and are less likely to loosen up.
We use a clear repair patch kind of tape to fix our tents called fixmytear repair tape. So much cheaper than paying a machinist to fix it. Apply it to both sides if you can for extra strength.
