Ir para o conteúdo principal
Sew a Ladder Stitch
O que você precisa
  1. Sew a Ladder Stitch, Sew a Ladder Stitch: passo 1, imagem 1 %32 Sew a Ladder Stitch, Sew a Ladder Stitch: passo 1, imagem 2 %32 Sew a Ladder Stitch, Sew a Ladder Stitch: passo 1, imagem 3 %32
    • Thread your needle and tie a knot in the end.
    • We're using contrasting thread for visibility, but when it comes time for your repair, you'll want to use matching thread.
    • Drive the needle from the back of the material, just before where the tear starts.
    • Pull the thread taut.
  2. Sew a Ladder Stitch: passo 2, imagem 1 %32 Sew a Ladder Stitch: passo 2, imagem 2 %32
    • Take a small stitch, going in and out of the material, on one side of the tear only.
  3. Sew a Ladder Stitch: passo 3, imagem 1 %32 Sew a Ladder Stitch: passo 3, imagem 2 %32
    • Take a small stitch, going in and out of the material, on the other side of the tear, directly opposite of the stitch you just took.
    • Pull the thread taut. This should cinch the material together.
    • If your material bunches, try taking smaller stitches, while ensuring that you line up the stitches on either side of the material.
  4. Sew a Ladder Stitch: passo 4, imagem 1 %32 Sew a Ladder Stitch: passo 4, imagem 2 %32
    • Continue stitching, switching from side to side as described in step 2 and 3 of this guide, pulling the thread taut after each stitch.
    • Stitch until you come to the end of the tear.
  5. Sew a Ladder Stitch: passo 5, imagem 1 %32 Sew a Ladder Stitch: passo 5, imagem 2 %32 Sew a Ladder Stitch: passo 5, imagem 3 %32
    • One the last stitch, drive the needle through both sides of the fabric, taking as small of a stitch as possible.
    • Slowly pull the thread. As you pull, a loop will form. Draw the needle through this loop, and pull the thread taut.
    • Repeat this step, taking a tiny stitch, drawing the needle through the loop, and pulling taut.
    • Ensure that the stitches are tight, and cut any excess threads.
Linha de Chegada
Brittany McCrigler
Membro desde: 03/05/12
89.128 Reputação
Autoria de 131 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.074 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 16
Últimos 30 dias: 105
Duração total: 10,093
