Introdução
This guide will show you how to take apart the fan to remove the Printed Circuit Board.
Peças
Não são necessárias peças.
  1. Use a Philips #2 screwdriver to unscrew the four 6mm Phillips #0 back screws.
    • Use a Philips #2 screwdriver to unscrew the four 6mm Phillips #0 back screws.
    • Do this by unscrewing from left-to-right then pull the screws out of the back of the fan
  2. Pull the front and back cover apart.
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely because it holds the wires.
  3. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Remove the Phillips (5-mm head) 6-mm screw that holds the circuit board to the outer shell of the fan.
    • Remove the Phillips (5-mm head) 6-mm screw that holds the circuit board to the outer shell of the fan.
    • Make sure the fan is unplugged while removing the circuit board as you may get shocked.
    • To remove the screws, unscrew in a left-to-right fashion at an angle to make sure that the wires do not get tangled.
  5. Remove the top cover containing the circuit board and the wires by pulling it away from the body of the fan.
    • Remove the top cover containing the circuit board and the wires by pulling it away from the body of the fan.
  6. Remove the circuit board from the top cover. Do not touch the other side of the circuit board as you  may damage circuit elements. Unscrew the four screws on the top of the circuit board in a left-to-right fashion. After pull screws out of the board.
    • Remove the circuit board from the top cover. Do not touch the other side of the circuit board as you may damage circuit elements.
    • Unscrew the four screws on the top of the circuit board in a left-to-right fashion. After pull screws out of the board.
Conclusão
Mateo Begue
87 reputação
2 Guides authored
Equipe
Cal Poly, Team 15-46, Forte Fall 2012 Membro de Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 Membros
6 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 894
