Ir para o conteúdo principal
Seville Classics MSC10166 Disassembly
O que você precisa
  1. Seville Classics MSC10166 Disassembly, PCB (Printed Circuit Board): passo 1, imagem 1 %32
    • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
  2. Seville Classics MSC10166 Disassembly: passo 2, imagem 1 %32
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
  3. Seville Classics MSC10166 Disassembly: passo 3, imagem 1 %32
    • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
  4. Seville Classics MSC10166 Disassembly: passo 4, imagem 1 %32
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
  5. Seville Classics MSC10166 Disassembly: passo 5, imagem 1 %32 Seville Classics MSC10166 Disassembly: passo 5, imagem 2 %32
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
  6. Seville Classics MSC10166 Disassembly, Rotating Blade and Transformer: passo 6, imagem 1 %32 Seville Classics MSC10166 Disassembly, Rotating Blade and Transformer: passo 6, imagem 2 %32
    • In order to remove the fan blade pliers were used to remove the holding nut.
    • After the holding nut is loose, use the pliers to pull up to remove the nut.
  7. Seville Classics MSC10166 Disassembly: passo 7, imagem 1 %32
    • Remove the two bronze Phillips 29-mm bolts that hold the fan blade to the transformer.
    • Use a pair of pliers to hold the nut at the bottom of the transformer, as you unscrew from left-to-right at the top of the transformer. After, pull up and remove both the screw and nut.
  8. Seville Classics MSC10166 Disassembly: passo 8, imagem 1 %32 Seville Classics MSC10166 Disassembly: passo 8, imagem 2 %32
    • Next, remove the two silver Phillips (8-mm head) 40-mm screws from the transformer.
    • Remove screws by pulling them away from the base.
    • The transformer should be free after this step.
  9. Seville Classics MSC10166 Disassembly, Seville Classics MSC10166: passo 9, imagem 1 %32 Seville Classics MSC10166 Disassembly, Seville Classics MSC10166: passo 9, imagem 2 %32
    • Clean the track, removing any obstructions.
    • Lubricate the track with grease.
Conclusão
Queena Phung
Membro desde: 09/26/12
114 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 15-46, Forte Fall 2012 Membro de Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 35
Duração total: 11,336
