Ir para o conteúdo principal
Seville Classics MSC10166 Disassembly
O que você precisa
  1. Seville Classics MSC10166 Disassembly, PCB (Printed Circuit Board): passo 1, imagem 1 %32
    • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
    Pergunte ao FixBot
    Comentar
  2. Seville Classics MSC10166 Disassembly: passo 2, imagem 1 %32
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
    Pergunte ao FixBot
    Comentar
  3. Seville Classics MSC10166 Disassembly: passo 3, imagem 1 %32
    • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
    Pergunte ao FixBot
    Comentar
  4. Seville Classics MSC10166 Disassembly: passo 4, imagem 1 %32
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
    Pergunte ao FixBot
    Comentar
  5. Seville Classics MSC10166 Disassembly: passo 5, imagem 1 %32 Seville Classics MSC10166 Disassembly: passo 5, imagem 2 %32
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
    Pergunte ao FixBot
    Comentar
  6. Seville Classics MSC10166 Disassembly, Rotating Blade and Transformer: passo 6, imagem 1 %32 Seville Classics MSC10166 Disassembly, Rotating Blade and Transformer: passo 6, imagem 2 %32
    • In order to remove the fan blade, use pliers to remove the holding nut.
    • After the holding nut is loose, use the pliers to pull up to remove the nut.
    Pergunte ao FixBot
    Comentar
  7. Seville Classics MSC10166 Disassembly: passo 7, imagem 1 %32
    • Remove the two bronze Phillips 29-mm bolts that hold the fan blade to the transformer.
    • Use a pair of pliers to hold the nut at the bottom of the transformer, as you unscrew from left-to-right at the top of the transformer. After, pull up and remove both the screw and nut.
    Pergunte ao FixBot
    Comentar
  8. Seville Classics MSC10166 Disassembly: passo 8, imagem 1 %32 Seville Classics MSC10166 Disassembly: passo 8, imagem 2 %32
    • Next, remove the two silver Phillips (8-mm head) 40-mm screws from the transformer.
    • Remove screws by pulling them away from the base.
    • The transformer should be free after this step.
    Pergunte ao FixBot
    Comentar
  9. Seville Classics MSC10166 Disassembly, Seville Classics MSC10166: passo 9, imagem 1 %32 Seville Classics MSC10166 Disassembly, Seville Classics MSC10166: passo 9, imagem 2 %32
    • Clean the track, removing any obstructions.
    • Lubricate the track with grease.
    Pergunte ao FixBot
    Comentar
Conclusão
Queena Phung
Membro desde: 09/26/12
114 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 15-46, Forte Fall 2012 Membro de Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 14
Últimos 7 dias: 36
Últimos 30 dias: 134
Ao todo: 12,553
