Ir para o conteúdo principal
Separate Samsung SGH-X105 Front & Back Panels
O que você precisa
  1. Separate Samsung SGH-X105 Front & Back Panels, Battery: passo 1, imagem 1 %32
    • Rotate the phone onto its front side so that the LCD screen is facing away from you.
  2. Separate Samsung SGH-X105 Front & Back Panels: passo 2, imagem 1 %32 Separate Samsung SGH-X105 Front & Back Panels: passo 2, imagem 2 %32 Separate Samsung SGH-X105 Front & Back Panels: passo 2, imagem 3 %32
    • Remove the battery by pressing down on the battery release button while sliding the battery downwards.
  3. Separate Samsung SGH-X105 Front & Back Panels, Front & Back Panels: passo 3, imagem 1 %32
    • Remove the four small black screws that secure the back phone panel using the Phillips #00 screwdriver.
    • Complete removal of screws may not be necessary.
  4. Separate Samsung SGH-X105 Front & Back Panels: passo 4, imagem 1 %32 Separate Samsung SGH-X105 Front & Back Panels: passo 4, imagem 2 %32 Separate Samsung SGH-X105 Front & Back Panels: passo 4, imagem 3 %32
    • Carefully separate the front and back panels by gently prying them apart. Start at the bottom of the phone (near the AC charger input).
    • Volume control button will be unsecured and may fall out as soon as the panels are separated.
    • Gentle force may be required to separate the panels at the top latch.
    • There are two wires connecting the front and back panels. Be careful not to rip these wires out when separating the panels.
  5. Separate Samsung SGH-X105 Front & Back Panels: passo 5, imagem 1 %32 Separate Samsung SGH-X105 Front & Back Panels: passo 5, imagem 2 %32
    • Using your nails, tweezers, or any precise grabbing tool, pinch the antenna wire connector (clear plastic plug) and pull gently. It should pop out rather easily.
Conclusão
DJ Tarazona
Membro desde: 04/13/10
58 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 28-29, Regan Spring 2010 Membro de Cal Poly, Team 28-29, Regan Spring 2010
CPSU-REGAN-S10S28G29
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,848
