Introdução
Normally these buttons get damaged from pushing them too hard. The tactile switch stops bending and making contact, or it just bends all the way and wont stop changing your settings.
Peças
Turn off the transmitter and take out the batteries.
16 outras pessoas concluíram este guia.
26 comentários
Hi -
I just want to say thank you! I made the repair exactly as shown and put a teeny drop of rubber cement in the middle of the new tactile plate to hold it in place, happy to say it all appears to work fine. As for the part itself, the part # is the same for the G3 and you can order from them in CT, USA.
cheers,
pete
Cool! I'm glad the guide helped you with your repair! do you happen to have the website for the store that sells them?
^_^
Angela
Yup! This works. :-)
I have the Sennheiser ew100 G3. The "down" arrow button was stuck and I couldn't change anything in my menus. What a pain!
So, I ordered two of the buttons from www.fullcompass.com this last week (item number 072512). At fullcompass, they call it a "Switch, Power SK100G2/SK100G3". It's the same button for the up arrow, down arrow, on/off and set buttons. It was $1.99 each and I ordered 2 plus $3 shipping.
I used a small screwdriver to gently pop the old button off and it actually came out in two pieces instead of one.
Anyway, I placed the new button on the little prongs and made sure it faced the same direction as the other buttons on the board. I put a little (and I mean little) piece of electrical tape over the side of the button. I'm talking like 1mm wide by 1cm long.
Screwed everything back together and voila! Working Sennheiser. Saved me almost $100 in repair. :-)
Thanks!
Always happy to know of a successful repair! Good job and thanks for sharing your story ^_^
What holds the new switch on? How are the contacts made without soldering?
