Ir para o conteúdo principal
Sennheiser HD 599 SE Earpad Replacement
  1. Sennheiser HD 599 SE Earpad Replacement, Earpad: passo 1, imagem 1 %32
    • Grip the underside of the earpad. Try to dig in as much as possible in order to get the best grip.
  2. Sennheiser HD 599 SE Earpad Replacement: passo 2, imagem 1 %32 Sennheiser HD 599 SE Earpad Replacement: passo 2, imagem 2 %32
    • Pull the earpad off while gripping it with your fingers.
  3. Sennheiser HD 599 SE Earpad Replacement: passo 3, imagem 1 %32
    • Using a tissue/microfibre cloth, clean the headset after removing the earpads.
  4. Sennheiser HD 599 SE Earpad Replacement: passo 4, imagem 1 %32 Sennheiser HD 599 SE Earpad Replacement: passo 4, imagem 2 %32
    • Align the new ear pads with the clips on the headphones.
  5. Sennheiser HD 599 SE Earpad Replacement: passo 5, imagem 1 %32
    • Snap the earpad in. Make sure to apply pressure on one side and work your way around until the earpad is secure.
  6. Sennheiser HD 599 SE Earpad Replacement: passo 6, imagem 1 %32
    • Repeat for the other side of the headphones.
Conclusão
To reassemble your device, follow these instructions in reverse order. Make sure to only use Earpads that are compatible with the Sennheiser HD 599 SE as using any other Earpad will damage your Headphones.
4 outras pessoas executaram este guia.
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 15
Últimos 7 dias: 45
Últimos 30 dias: 150
Duração total: 12,305
