Introdução
This is a Sennheiser HD 4.50 Headphone motherboard repair guide. This guide is useful for users whose headphones are not properly functioning due to issues with the motherboard. The motherboard is the main control system for the headphone where all electrical connections run. A faulty motherboard could cause many problems to the headphones from volume issues all the way to complete headphone failure. If the users headphones seem to be experiencing electrical/technical issues, this guide is a good place to turn.
In Step 4 you will require you to remove wires that have been hot glued down to the motherboard. Make sure to use safe practices to ensure everything goes safely.
O que você precisa
Locate the side designation on the headband-earpiece junction.
Remove the right side ear pad.
