Ir para o conteúdo principal
Sennheiser HD 4.50 Motherboard Replacement
O que você precisa
  1. Sennheiser HD 4.50 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Sennheiser HD 4.50 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 Sennheiser HD 4.50 Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Locate the side designation on the headband-earpiece junction.
    • The motherboard is located on the right side.
    • Remove the right side ear pad.
    • Refer to the Ear Pad Removal guide for more guidance.
  2. Sennheiser HD 4.50 Motherboard Replacement: passo 2, imagem 1 %32 Sennheiser HD 4.50 Motherboard Replacement: passo 2, imagem 2 %32 Sennheiser HD 4.50 Motherboard Replacement: passo 2, imagem 3 %32
    • Use the Phillips #00 screwdriver to remove the four 10 mm screws holding the ear cup cover in place.
    • Use an opening tool to pry off the cover.
  3. Sennheiser HD 4.50 Motherboard Replacement: passo 3, imagem 1 %32 Sennheiser HD 4.50 Motherboard Replacement: passo 3, imagem 2 %32 Sennheiser HD 4.50 Motherboard Replacement: passo 3, imagem 3 %32
    • Use a Phillips #000 screwdriver to remove the four 6 mm screws holding the motherboard in place.
  4. Sennheiser HD 4.50 Motherboard Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to remove the hot glue that covers the wires
    • Using the tweezers, grasp and slowly pull away the wires from the motherboard until they disconnect.
  5. Sennheiser HD 4.50 Motherboard Replacement: passo 5, imagem 1 %32
    • Use the iFixit opening tools to lift up on the motherboard.
    • While lifting up with the tool, grab and pull the motherboard with your free hand away from the button functions until it disconnects.
    • There may be some resistance in this step.
  6. Sennheiser HD 4.50 Motherboard Replacement: passo 6, imagem 1 %32
    • Desolder the three wires that are on the underside of the motherboard now that it is free.
    • Remove the motherboard.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 31
Últimos 30 dias: 126
Duração total: 2,435
