Introdução
If the headband pad or cushion on your Sennheiser HD 4.50 headphones are worn down or damaged, use this guide for instructions on replacing it. In order to complete this repair, you will need to buy a new headband pad to replace the defective one you are removing.
O que você precisa
Extend the headphones by pulling the headband away from the base of the headphones.
Uma outra pessoa concluiu este guia.
Um comentário
Is there any guide on replacing the hinge that the ear cups are connected to?
