Ir para o conteúdo principal
Seiko Strap Adjustment
  1. Seiko Strap Adjustment, Strap Links: passo 1, imagem 1 %32
    • Note the arrow direction on each link.
    • Note the orientation of each pin upon removal.
  2. Seiko Strap Adjustment: passo 2, imagem 1 %32 Seiko Strap Adjustment: passo 2, imagem 2 %32
    • Push pins out in the direction of link arrows.
    • Use either a strong tweezer or P2 bit.
    • avoid scratching by putting an old T-shirt down on your work surface.
    • expect to push hard. Pins go out in the direction of the arrow on the link.
  3. Seiko Strap Adjustment: passo 3, imagem 1 %32 Seiko Strap Adjustment: passo 3, imagem 2 %32
    • Pull pins out slowly.
    • Note the orientation of each pin.
    • Expect the watch to fall apart.
  4. Seiko Strap Adjustment: passo 4, imagem 1 %32
    • Push pins opposite direction of link arrows to insert.
    • This may require a lot of force.
    • Brace your workspace and use soft linens to avoid scratches.
  5. Seiko Strap Adjustment: passo 5, imagem 1 %32
    • Remove and replace as many links as needed to adjust strap length.
Conclusão
3 outras pessoas executaram este guia.
Dean Gadberry
Membro desde: 02/27/21
424 Reputação
Autoria de 2 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 20
Últimos 30 dias: 45
Ao todo: 308
