Ir para o conteúdo principal
Segway Ninebot Max Battery Replacement
O que você precisa
  1. Segway Ninebot Max Battery Replacement, Remove the base plate: passo 1, imagem 1 %32 Segway Ninebot Max Battery Replacement, Remove the base plate: passo 1, imagem 2 %32
    • Flip the scooter upside down and unscrew the 18 screws holding the base plate using a Security Torx T15 screwdriver.
  2. Segway Ninebot Max Battery Replacement, Remove the old battery: passo 2, imagem 1 %32 Segway Ninebot Max Battery Replacement, Remove the old battery: passo 2, imagem 2 %32
    • Unscrew the 10 screws that hold the battery onto the frame and remove the battery from the enclosure.
    • Unplug any connectors that connect the battery and scooter together.
  3. Segway Ninebot Max Battery Replacement, Place the new battery inside: passo 3, imagem 1 %32
    • Place the new battery inside the enclosure and reinstall the 10 screws (if needed), bonding the battery to the scooter.
  4. Segway Ninebot Max Battery Replacement, Connect the battery: passo 4, imagem 1 %32 Segway Ninebot Max Battery Replacement, Connect the battery: passo 4, imagem 2 %32
    • Connect the pins from the battery and scooter together.
    • Make sure to tuck in the wiring.
  5. Segway Ninebot Max Battery Replacement, Test the battery: passo 5, imagem 1 %32
    • Turn on the scooter and accelerate to make sure there are no errors and the scooter is running.
  6. Segway Ninebot Max Battery Replacement, Reattach the base plate: passo 6, imagem 1 %32 Segway Ninebot Max Battery Replacement, Reattach the base plate: passo 6, imagem 2 %32
    • Line up the base plate and tighten it with all 18 screws using a Security Torx T15 Allen Key.
Conclusão
6 outras pessoas executaram este guia.
sunny sanghera
Membro desde: 05/14/21
248 Reputação
Autoria de 1 guia
Equipe
5 comentários
Do you know where I can purchase a replacement battery for the Ninebot Max? I can't seem to find one.
Chip Bates - Responder
If you find a new battery will you put me onto it aswell I need one do you know how much they are thanks in advance
Andrew Leslie -
Do you guys recommend purchasing any brand battery charger for your Ninebot Segway Scooter 🛴 or should I stick with the actual "Segway" brand charger from their official site??? Is there really a difference or is one just as good as the other???
Jessica Loftis - Responder
looking for battery for ninebot zing e10 scooter
Isaac L - Responder
Am o problema, când bateria trotinete ajunge la jumate se oprește, un răspuns va rog!
Gabi Gabrieluu - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 42
Últimos 7 dias: 267
Últimos 30 dias: 1,196
Duração total: 28,085
