Ir para o conteúdo principal
Sega Saturn Power Supply Replacement
O que você precisa
  1. Sega Saturn Power Supply Replacement, Battery: passo 1, imagem 1 %32 Sega Saturn Power Supply Replacement, Battery: passo 1, imagem 2 %32
    • Press on the plastic lever on the back of the Sega Saturn to pop open the battery slot.
  2. Sega Saturn Power Supply Replacement: passo 2, imagem 1 %32 Sega Saturn Power Supply Replacement: passo 2, imagem 2 %32 Sega Saturn Power Supply Replacement: passo 2, imagem 3 %32
    • Push up the edge of the battery with the iFixit opening tool to get the battery out of its socket.
  3. Sega Saturn Power Supply Replacement: passo 3, imagem 1 %32 Sega Saturn Power Supply Replacement: passo 3, imagem 2 %32 Sega Saturn Power Supply Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use the ESD safe tweezers to pull the battery out of its slot.
  4. Sega Saturn Power Supply Replacement, Case: passo 4, imagem 1 %32 Sega Saturn Power Supply Replacement, Case: passo 4, imagem 2 %32 Sega Saturn Power Supply Replacement, Case: passo 4, imagem 3 %32
    • Remove the five black 13.5mm JIS#1 screws on the bottom of the device. One might be hidden by a sticker.
  5. Sega Saturn Power Supply Replacement: passo 5, imagem 1 %32 Sega Saturn Power Supply Replacement: passo 5, imagem 2 %32 Sega Saturn Power Supply Replacement: passo 5, imagem 3 %32
    • Flip the device over so it rests right side up.
    • Lift gently across the seam of the Sega Saturn. If parts get stuck, a light shake or prying with the iFixit opening tool should free it up. Do not use any brute force, as this can damage the case so it doesn't close again.
  6. Sega Saturn Power Supply Replacement, Power Supply: passo 6, imagem 1 %32 Sega Saturn Power Supply Replacement, Power Supply: passo 6, imagem 2 %32
    • Unplug the power button plug on the power supply board. Use the iFixit opening tool if necessary.
  7. Sega Saturn Power Supply Replacement: passo 7, imagem 1 %32 Sega Saturn Power Supply Replacement: passo 7, imagem 2 %32 Sega Saturn Power Supply Replacement: passo 7, imagem 3 %32
    • Remove the two black 11.4mm standoff screws on the back of the Sega Saturn holding the power socket in place. These screws are tight and easily stripped, so it's suggested to use a standoff screw head.
  8. Sega Saturn Power Supply Replacement: passo 8, imagem 1 %32 Sega Saturn Power Supply Replacement: passo 8, imagem 2 %32
    • Remove the metallic 12.3mm JIS#1 screw holding down the power supply board.
  9. Sega Saturn Power Supply Replacement: passo 9, imagem 1 %32 Sega Saturn Power Supply Replacement: passo 9, imagem 2 %32 Sega Saturn Power Supply Replacement: passo 9, imagem 3 %32
    • Lift the power supply board out of its socket, minding the pins that connect it to the motherboard. Some force will be required, but be careful when lifting or shaking the power supply board out.
Conclusão
Jan Ulloa
Membro desde: 10/15/19
630 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G6, Leahy Fall 2019 Membro de USF Tampa, Team S1-G6, Leahy Fall 2019
USFT-LEAHY-F19S1G6
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 27
Últimos 30 dias: 142
Duração total: 5,049
