Ir para o conteúdo principal
Sega Saturn Motherboard Replacement
O que você precisa
  1. Sega Saturn Motherboard Replacement, Battery: passo 1, imagem 1 %32 Sega Saturn Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Press on the plastic lever on the back of the Sega Saturn to pop open the battery slot.
  2. Sega Saturn Motherboard Replacement: passo 2, imagem 1 %32 Sega Saturn Motherboard Replacement: passo 2, imagem 2 %32 Sega Saturn Motherboard Replacement: passo 2, imagem 3 %32
    • Push up the edge of the battery with the iFixit opening tool to get the battery out of its socket.
  3. Sega Saturn Motherboard Replacement: passo 3, imagem 1 %32 Sega Saturn Motherboard Replacement: passo 3, imagem 2 %32 Sega Saturn Motherboard Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use the ESD safe tweezers to pull the battery out of its slot.
  4. Sega Saturn Motherboard Replacement, Case: passo 4, imagem 1 %32 Sega Saturn Motherboard Replacement, Case: passo 4, imagem 2 %32 Sega Saturn Motherboard Replacement, Case: passo 4, imagem 3 %32
    • Remove the five black 13.5mm JIS#1 screws on the bottom of the device. One might be hidden by a sticker.
  5. Sega Saturn Motherboard Replacement: passo 5, imagem 1 %32 Sega Saturn Motherboard Replacement: passo 5, imagem 2 %32 Sega Saturn Motherboard Replacement: passo 5, imagem 3 %32
    • Flip the device over so it rests right side up.
    • Lift gently across the seam of the Sega Saturn. If parts get stuck, a light shake or prying with the iFixit opening tool should free it up. Do not use any brute force, as this can damage the case so it doesn't close again.
  6. Sega Saturn Motherboard Replacement, Power Supply: passo 6, imagem 1 %32 Sega Saturn Motherboard Replacement, Power Supply: passo 6, imagem 2 %32
    • Unplug the power button plug on the power supply board. Use the iFixit opening tool if necessary.
  7. Sega Saturn Motherboard Replacement: passo 7, imagem 1 %32 Sega Saturn Motherboard Replacement: passo 7, imagem 2 %32 Sega Saturn Motherboard Replacement: passo 7, imagem 3 %32
    • Remove the two black 11.4mm standoff screws on the back of the Sega Saturn holding the power socket in place. These screws are tight and easily stripped, so it's suggested to use a standoff screw head.
  8. Sega Saturn Motherboard Replacement: passo 8, imagem 1 %32 Sega Saturn Motherboard Replacement: passo 8, imagem 2 %32
    • Remove the metallic 12.3mm JIS#1 screw holding down the power supply board.
  9. Sega Saturn Motherboard Replacement: passo 9, imagem 1 %32 Sega Saturn Motherboard Replacement: passo 9, imagem 2 %32 Sega Saturn Motherboard Replacement: passo 9, imagem 3 %32
    • Lift the power supply board out of its socket, minding the pins that connect it to the motherboard. Some force will be required, but be careful when lifting or shaking the power supply board out.
  10. Sega Saturn Motherboard Replacement, Power Button: passo 10, imagem 1 %32 Sega Saturn Motherboard Replacement, Power Button: passo 10, imagem 2 %32 Sega Saturn Motherboard Replacement, Power Button: passo 10, imagem 3 %32
    • Remove the metallic 13.7mm JIS#1 screw on the right of the Power Button.
    • Remove the metallic 12.4mm JIS#1 screw on the left of the Power Button.
  11. Sega Saturn Motherboard Replacement: passo 11, imagem 1 %32 Sega Saturn Motherboard Replacement: passo 11, imagem 2 %32
    • Push the plastic resting tray’s pin located here.
    • Remove the plastic resting tray to free the wire between the power supply board and the button.
    • Remove the power button when the wire is free.
  12. Sega Saturn Motherboard Replacement, Disc Reader: passo 12, imagem 1 %32
    • Do not touch the laser reader, as smudges have been reported to ruin it.
  13. Sega Saturn Motherboard Replacement: passo 13, imagem 1 %32 Sega Saturn Motherboard Replacement: passo 13, imagem 2 %32
    • Pull firmly on the ribbon cable from the end on the motherboard.
    • Don't worry about pulling it out of its socket; it can be plugged back in.
  14. Sega Saturn Motherboard Replacement: passo 14, imagem 1 %32 Sega Saturn Motherboard Replacement: passo 14, imagem 2 %32 Sega Saturn Motherboard Replacement: passo 14, imagem 3 %32
    • Pry the second cable out of its socket on the disk reader with the iFixit opening tool or ESD safe tweezers. When the lip of the cable gets enough distance out of the socket, it can be wiggled free.
  15. Sega Saturn Motherboard Replacement: passo 15, imagem 1 %32 Sega Saturn Motherboard Replacement: passo 15, imagem 2 %32 Sega Saturn Motherboard Replacement: passo 15, imagem 3 %32
    • Lift the laser reader slowly out of its slot hosted by these four pins. There is a screw underneath with a cable attached to the motherboard.
  16. Sega Saturn Motherboard Replacement: passo 16, imagem 1 %32 Sega Saturn Motherboard Replacement: passo 16, imagem 2 %32 Sega Saturn Motherboard Replacement: passo 16, imagem 3 %32
    • Remove the metallic 12.2mm JIS #1 screw. This will need additional hands in reverse to hold the disk reader steady.
    • Remove the yellow tape on the reader strip and gently remove the disc reader without touching the laser reader.
  17. Sega Saturn Motherboard Replacement, Motherboard: passo 17, imagem 1 %32 Sega Saturn Motherboard Replacement, Motherboard: passo 17, imagem 2 %32 Sega Saturn Motherboard Replacement, Motherboard: passo 17, imagem 3 %32
    • Remove the four metallic 15.5mm JIS#1 screws from the Motherboard Frame.
    • Remove the four metallic 13.6mm JIS#1 screws from the Motherboard Frame.
    • Remove the metallic 12.3mm JIS#1 screw from the Motherboard Frame.
  18. Sega Saturn Motherboard Replacement: passo 18, imagem 1 %32 Sega Saturn Motherboard Replacement: passo 18, imagem 2 %32 Sega Saturn Motherboard Replacement: passo 18, imagem 3 %32
    • Lift the motherboard frame out carefully because of the delicate parts on the motherboard.
    • You do not need to remove the plastic Power LED Reflector. If it does pop out, don't worry, it can be pushed back into its socket. It may require rotation to fit the case when closed.
  19. Sega Saturn Motherboard Replacement: passo 19, imagem 1 %32 Sega Saturn Motherboard Replacement: passo 19, imagem 2 %32 Sega Saturn Motherboard Replacement: passo 19, imagem 3 %32
    • Lift the motherboard away from the controller sockets in the front of the device while keeping your hands on the edges of the board
    • Once the back of the motherboard is above the back of the case, lift backwards to pull the cables out of their sockets to free the motherboard.
Conclusão
Jan Ulloa
Membro desde: 10/15/19
630 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G6, Leahy Fall 2019 Membro de USF Tampa, Team S1-G6, Leahy Fall 2019
USFT-LEAHY-F19S1G6
Membros da 3
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 55
Últimos 30 dias: 185
Duração total: 6,560
