Ir para o conteúdo principal
Sega Master System Model 2 Disassembly
O que você precisa
Vídeo de Apresentação
  1. Sega Master System Model 2 Disassembly, The Case: passo 1, imagem 1 %32
    • Take out the 5 screws at the bottom
  2. Sega Master System Model 2 Disassembly, RF Shield: passo 2, imagem 1 %32
    • Remove the 5 screws (3 at the back and 2 on the front)
    • Remove the screw at the side (this screws is different then the other 5 so remember to put them away from the other 5 screws since they are similar)
    • This screw is for the rf shield under for the voltage regulator under this bigger rf shield, its not needed to remove that screw
  3. Sega Master System Model 2 Disassembly, Cartridge Slot: passo 3, imagem 1 %32
    • Remove the 2 screws thats holding the cartridge slot down
  4. Sega Master System Model 2 Disassembly, The End: passo 4, imagem 1 %32
    • Congratulations! You have opened your Sega Master System Model 2!
Conclusão
Screenshots taken from a video by Global Garage
3 outras pessoas executaram este guia.
Krisow
Membro desde: 10/18/17
605 Reputação
Autoria de 2 guias
3 comentários
This is in the wrong section.
Owen Ready - Responder
Nope, its in the Sega Master System area.
Krisow -
Not a Master System
Chad Luciano - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 38
Duração total: 2,336
