Introdução
Wireless controllers have many advantages over wired ones. However, these controllers will eventually run out of charge. This guide will show you how to replace the batteries in your controller.
O que você precisa
Using a Phillips #000 screwdriver, unscrew the single screw located on the battery cover. Remove the battery cover and set it aside.
If batteries are in the battery slots and need to be replaced, then remove the old batteries by pressing them in and compressing the spring until there is enough space to take them out.
Insert two fresh batteries into each one of the slots by pushing the indicated negative end of the battery against the spring.
Um comentário
any idea where i can find a schematic for the contoller board. I just bought one of these second hand and the wireless controller won’t connect to the system. I took it apart and it’s missing a small resistor.
