Ir para o conteúdo principal
Sega Genesis Flashback Controller Batteries Replacement
O que você precisa
  1. Sega Genesis Flashback Controller Batteries Replacement, Controller Batteries: passo 1, imagem 1 %32 Sega Genesis Flashback Controller Batteries Replacement, Controller Batteries: passo 1, imagem 2 %32
    • Using a Phillips #000 screwdriver, unscrew the single screw located on the battery cover. Remove the battery cover and set it aside.
    • The screw does not detach from the battery cover, so do not attempt to separate them.
  2. Sega Genesis Flashback Controller Batteries Replacement: passo 2, imagem 1 %32 Sega Genesis Flashback Controller Batteries Replacement: passo 2, imagem 2 %32
    • If batteries are in the battery slots and need to be replaced, then remove the old batteries by pressing them in and compressing the spring until there is enough space to take them out.
    • Insert two fresh batteries into each one of the slots by pushing the indicated negative end of the battery against the spring.
    • All AAA batteries have “+” and “-” symbols on each end of the batteries to denote the positive and negative ends.
Conclusão
Omar Shorab
Membro desde: 04/23/18
261 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S24-G12, Maness Spring 2018 Membro de Cal Poly, Team S24-G12, Maness Spring 2018
CPSU-MANESS-S18S24G12
Membros da 4
Autoria de 10 guias
Um comentário
any idea where i can find a schematic for the contoller board. I just bought one of these second hand and the wireless controller won’t connect to the system. I took it apart and it’s missing a small resistor.
Scott Phaneuf - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 26
Duração total: 2,601
