Ir para o conteúdo principal
Sega Game Gear Case Replacement
O que você precisa
  1. Sega Game Gear Case Replacement, Battery: passo 1, imagem 1 %32
    • Place your device upside down and locate the two battery compartments.
  2. Sega Game Gear Case Replacement: passo 2, imagem 1 %32
    • Press on the tabs at the bottom of the battery covers then lift up to remove.
    • Remove batteries if they are present.
  3. Sega Game Gear Case Replacement, Case: passo 3, imagem 1 %32
    • Remove the following screws:
    • Six Phillips screws
    • One 4.5 mm Gamebit screw
  4. Sega Game Gear Case Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to take all other screws out.
  5. Sega Game Gear Case Replacement: passo 5, imagem 1 %32 Sega Game Gear Case Replacement: passo 5, imagem 2 %32
    • Gently open the case by unfolding it over the top of the Sega Game Gear.
    • Do not pull the back of the case away, as cables are connected between both sides.
  6. Sega Game Gear Case Replacement: passo 6, imagem 1 %32 Sega Game Gear Case Replacement: passo 6, imagem 2 %32 Sega Game Gear Case Replacement: passo 6, imagem 3 %32
    • Carefully unplug the 2 white-tipped connectors on the top cover.
Conclusão
10 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 28-33, Regan Spring 2010 Membro de Cal Poly, Team 28-33, Regan Spring 2010
CPSU-REGAN-S10S28G33
5 Membros
Autoria de 20 guias
1Comentário do guia
Is this guide made to help replacing the Game Gear shell? Almost doesn't seem like a thorough guide, I'm still seeing screws on the motherboard in the last photo, I assume those get taken out too?
Alex Tomalty - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 26
Últimos 30 dias: 128
Ao todo: 21,525
