Ir para o conteúdo principal
Sega Dreamcast Top Cover Replacement
O que você precisa
  1. Sega Dreamcast Top Cover Replacement, Expansion Bay: passo 1, imagem 1 %32 Sega Dreamcast Top Cover Replacement, Expansion Bay: passo 1, imagem 2 %32
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Sega Dreamcast Top Cover Replacement: passo 2, imagem 1 %32 Sega Dreamcast Top Cover Replacement: passo 2, imagem 2 %32 Sega Dreamcast Top Cover Replacement: passo 2, imagem 3 %32
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Sega Dreamcast Top Cover Replacement, Top Cover: passo 3, imagem 1 %32
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Sega Dreamcast Top Cover Replacement: passo 4, imagem 1 %32
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
Conclusão
6 outras pessoas executaram este guia.
wkwong
Membro desde: 11/14/09
533 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 5-1, Regan Fall 2009 Membro de Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
Membros da 5
Autoria de 21 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 19
Últimos 30 dias: 58
Duração total: 12,019
