Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
A guide to remove the Logic Board from the Sega Dreamcast.
  1. Verify that the console is disconnected from the AC outlet before you begin. Flip the console over on its back.
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
  5. Verify that the console is disconnected from the AC outlet before you begin. If you have just powered off the system, give the capacitors a few minutes to discharge before you begin working. Remove the white female pin header by clamping the clip and pulling it up gently from the power board.
    • Verify that the console is disconnected from the AC outlet before you begin. If you have just powered off the system, give the capacitors a few minutes to discharge before you begin working.
    • Remove the white female pin header by clamping the clip and pulling it up gently from the power board.
  6. Remove the two 10mm Philips #02 screws that are fastened to the power block.
    • Remove the two 10mm Philips #02 screws that are fastened to the power block.
  7. Do not bend the male pin header between the mounted head when you remove the power supply from the chassis. Remove the power board by using both hands to gently lift the power board away from the console.
    • Do not bend the male pin header between the mounted head when you remove the power supply from the chassis.
    • Remove the power board by using both hands to gently lift the power board away from the console.
  8. Remove the clear plastic film that is tucked between the power supply and the chassis.
    • Remove the clear plastic film that is tucked between the power supply and the chassis.
  9. Telas LCD de reposição iPhone (com ferramentas)
    A opção econômica, coberta por nossa garantia vitalícia.
    Confira os kits
    Reduza os custos de reparo, não a qualidade.
    Confira os kits
  10. Be gentle with the white controller cable as it can be a bit fragile. Disconnect the white controller cable by gently pulling the the cable while wiggling it back and forth until it detaches from the controller board.
    • Be gentle with the white controller cable as it can be a bit fragile.
    • Disconnect the white controller cable by gently pulling the the cable while wiggling it back and forth until it detaches from the controller board.
  11. Remove the four 14mm Philips #02 screws located on the controller board. Remove the four 14mm Philips #02 screws located on the controller board.
    • Remove the four 14mm Philips #02 screws located on the controller board.
  12. Disconnect the white fan header from the controller port. Disconnect the white fan header from the controller port.
    • Disconnect the white fan header from the controller port.
  13. Remove the controller board by lifting it up from the controller port. Remove the controller board by lifting it up from the controller port.
    • Remove the controller board by lifting it up from the controller port.
  14. Detach the orange cable  by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board. Detach the orange cable  by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
    • Detach the orange cable by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
  15. Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board. Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board.
    • Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board.
  16. Remove the two black 12mm Philips #02 screws located on the left side of the GD-ROM bracket. The console is rotated 90 degrees counter-clockwise in the first photo. The second photo depicts the normal position.
    • Remove the two black 12mm Philips #02 screws located on the left side of the GD-ROM bracket.
    • The console is rotated 90 degrees counter-clockwise in the first photo. The second photo depicts the normal position.
  17. When lifting the GD-ROM, be careful that the top half of the casing does not detached from its base. Remove the GD-ROM by gently lifting it from its base.
    • When lifting the GD-ROM, be careful that the top half of the casing does not detached from its base.
    • Remove the GD-ROM by gently lifting it from its base.
  18. Remove the white fan header by gently pulling it away from from the controller port.
    • Remove the white fan header by gently pulling it away from from the controller port.
    • The white fan header may already be detached if you have completed the Controller Port Disassembly Guide.
  19. Remove the two 8.5mm Philips #00 screws from the fan bracket.
    • Remove the two 8.5mm Philips #00 screws from the fan bracket.
  20. Remove the two 17.5mm Philips #00 screws from the fan bracket. Remove the fan from the bracket.
    • Remove the two 17.5mm Philips #00 screws from the fan bracket.
    • Remove the fan from the bracket.
  21. Remove the five 10mm Philips #02 screws from left side of the logic board cover. Remove the three black 12mm Philips #02 screws from the right side of the logic board cover. Remove the three black 12mm Philips #02 screws from the right side of the logic board cover.
    • Remove the five 10mm Philips #02 screws from left side of the logic board cover.
    • Remove the three black 12mm Philips #02 screws from the right side of the logic board cover.
  22. Lift the metal cover from the console. Lift the metal cover from the console. Lift the metal cover from the console.
    • Lift the metal cover from the console.
  23. Before handing the logic board, you may want to use a grounding strap to protect the device from static charge. If you do not have a grounding strip, you may ground yourself by touching a large metallic object. Remove the logic board and set the logic board on an anti-static surface.
    • Before handing the logic board, you may want to use a grounding strap to protect the device from static charge. If you do not have a grounding strip, you may ground yourself by touching a large metallic object.
    • Remove the logic board and set the logic board on an anti-static surface.
Conclusão
14 outras pessoas concluíram este guia.
wkwong
Membro desde: 14-11-2009
429 Reputação
5 Guias de autoria
equipe
Cal Poly, Team 5-1, Regan Fall 2009 Membro de Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 Membros
18 Guias de autoria
helpful but my dreamcast had a different logic board and as well as fan and gd-rom so keep that in mind if u see something different in your unit
Nickolas Wilcox - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 34
Últimos 30 dias: 125
Duração total: 15,774
