Ir para o conteúdo principal
Sega Dreamcast GD-ROM Replacement
O que você precisa
  1. Sega Dreamcast GD-ROM Replacement, Expansion Bay: passo 1, imagem 1 %32 Sega Dreamcast GD-ROM Replacement, Expansion Bay: passo 1, imagem 2 %32
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Sega Dreamcast GD-ROM Replacement: passo 2, imagem 1 %32 Sega Dreamcast GD-ROM Replacement: passo 2, imagem 2 %32 Sega Dreamcast GD-ROM Replacement: passo 2, imagem 3 %32
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Sega Dreamcast GD-ROM Replacement, Top Cover: passo 3, imagem 1 %32
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Sega Dreamcast GD-ROM Replacement: passo 4, imagem 1 %32
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
  5. Sega Dreamcast GD-ROM Replacement, GD-ROM: passo 5, imagem 1 %32 Sega Dreamcast GD-ROM Replacement, GD-ROM: passo 5, imagem 2 %32
    • Detach the orange cable by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
  6. Sega Dreamcast GD-ROM Replacement: passo 6, imagem 1 %32 Sega Dreamcast GD-ROM Replacement: passo 6, imagem 2 %32
    • Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board.
  7. Sega Dreamcast GD-ROM Replacement: passo 7, imagem 1 %32 Sega Dreamcast GD-ROM Replacement: passo 7, imagem 2 %32
    • Remove the two black 12mm Philips #02 screws located on the left side of the GD-ROM bracket.
    • The console is rotated 90 degrees counter-clockwise in the first photo. The second photo depicts the normal position.
  8. Sega Dreamcast GD-ROM Replacement: passo 8, imagem 1 %32 Sega Dreamcast GD-ROM Replacement: passo 8, imagem 2 %32
    • When lifting the GD-ROM, be careful that the top half of the casing does not detached from its base.
    • Remove the GD-ROM by gently lifting it from its base.
  9. Sega Dreamcast GD-ROM Replacement, GD-ROM: passo 9, imagem 1 %32 Sega Dreamcast GD-ROM Replacement, GD-ROM: passo 9, imagem 2 %32
    • Replace the bad GD-ROM drive with a functional one.
  10. Sega Dreamcast GD-ROM Replacement: passo 10, imagem 1 %32 Sega Dreamcast GD-ROM Replacement: passo 10, imagem 2 %32
    • Secure the new GD-ROM drive to the console with the Philips #2 screws.
  11. Sega Dreamcast GD-ROM Replacement: passo 11, imagem 1 %32 Sega Dreamcast GD-ROM Replacement: passo 11, imagem 2 %32 Sega Dreamcast GD-ROM Replacement: passo 11, imagem 3 %32
    • Connect the three GD-ROM cables to the logic board.
    • Connect the GD-ROM data ribbon to the logic board.
Linha de Chegada
10 outras pessoas executaram este guia.
Thorr686
Membro desde: 11/06/09
500 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 5-1, Regan Fall 2009 Membro de Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 Membros
Autoria de 21 guias
2Comentários do guia
If only it was that simple Sega screwed U.K gamers over with the fact we have to buy totally new consoles due to the wires of the disk drive being soldered in rather than clipped in.
Anthony Salmon - Responder
My HKT-3020 console, NTSC-U revision 1, manufactured in Japan during 4/2000, does not have the orange cable shown in step 5. I was able to skip steps 5 and 6, and for step 7 I had to remove 3 screws, not 2. My GD-ROM drive came as an assembly, mounted on a metal plate; the entire assembly simply lowers into a connector port. After removing the screws, I just had to gently wiggle it up and out of the port, then lower the replacement assembly into the same port, and replace the 3 screws.
Aaron Teplitsky - Responder
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 61
Últimos 30 dias: 239
Ao todo: 36,930
