Introdução
A guide to remove the GD-ROM from the Sega Dreamcast.
Peças
Não são necessárias peças.
Verify that the console is disconnected from the AC outlet before you begin.
  • Verify that the console is disconnected from the AC outlet before you begin.
  • Flip the console over on its back.
  • Take note of your model number, in case replacement parts are needed.
Adicionar comentário
Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
  • Note: Remove the expansion bay to locate the fourth screw
  • Internal components can be loose. Be careful that they do not fall out when removing the cover.
  • Turn the console right side up.
  • Remove the top cover by gently lifting the upper portion of the console.
  • Be gentle with the white controller cable as it can be a bit fragile.
  • Disconnect the white controller cable by gently pulling the the cable while wiggling it back and forth until it detaches from the controller board.
  • Remove the four 14mm Philips #02 screws located on the controller board.
  • Disconnect the white fan header from the controller port.
  • Remove the controller board by lifting it up from the controller port.
Conclusão
Uma outra pessoa concluiu este guia.
wkwong
414 reputação
13 Guides authored
Equipe
Cal Poly, Team 5-1, Regan Fall 2009 Membro de Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 Membros
23 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 35
Todo: 5,338
