Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Sega CD CD Tray Replacement
O que você precisa
  1. Sega CD CD Tray Replacement, Sega CD Plastic Housing Removal: passo 1, imagem 1 %32 Sega CD CD Tray Replacement, Sega CD Plastic Housing Removal: passo 1, imagem 2 %32
    • Using a Phillips head screwdriver remove six screws from the bottom of the console.
    • The six screws are marked.
  2. Sega CD CD Tray Replacement: passo 2, imagem 1 %32
    • Remove the two screws that attach the Genesis' connector to the rest of the console.
    • The two screws are marked in the diagram.
  3. Sega CD CD Tray Replacement: passo 3, imagem 1 %32
    • Slide the lock tab to the left to separate the halves of the console.
  4. Sega CD CD Tray Replacement: passo 4, imagem 1 %32
    • Lift from the left side to remove the top of the case.
  5. Sega CD CD Tray Replacement: passo 5, imagem 1 %32
    • Using the spudger, pry the cover off of the Genesis attachment.
  6. Sega CD CD Tray Replacement: passo 6, imagem 1 %32
    • Lift the top of the case to remove the cover.
  7. Sega CD CD Tray Replacement: passo 7, imagem 1 %32
    • Remove the faceplate by pulling it up, then out.
  8. Sega CD CD Tray Replacement, CD Tray: passo 8, imagem 1 %32 Sega CD CD Tray Replacement, CD Tray: passo 8, imagem 2 %32
    • Remove metal plate by unscrewing the three screws with the Phillips head screwdriver and then lifting the plate.
    • The three screws are shown on the diagram.
  9. Sega CD CD Tray Replacement: passo 9, imagem 1 %32 Sega CD CD Tray Replacement: passo 9, imagem 2 %32
    • Remove the two screws from the plastic bar.
    • The two screws are shown pictured.
  10. Sega CD CD Tray Replacement: passo 10, imagem 1 %32 Sega CD CD Tray Replacement: passo 10, imagem 2 %32
    • To remove the CD tray
    • Remove the four screws with the Phillips head screwdriver.
  11. Sega CD CD Tray Replacement: passo 11, imagem 1 %32
    • Carefully unplug the wire connected to optical reader.
  12. Sega CD CD Tray Replacement: passo 12, imagem 1 %32 Sega CD CD Tray Replacement: passo 12, imagem 2 %32
    • Remove the four screws on the underside of the CD tray with a small Phillips head screwdriver.
    • The four screws are highlighted on the diagram.
    • The four springs below the circuit board are attached to the screws, so be careful not to lose them when you remove the screws.
  13. Sega CD CD Tray Replacement: passo 13, imagem 1 %32
    • Carefully remove the CD tray from circuit board.
Conclusão
Uma outra pessoa concluiu este guia.
sskyllin
Membro desde: 10/18/10
21 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 5-14, Maness Fall 2010 Membro de Cal Poly, Team 5-14, Maness Fall 2010
CPSU-MANESS-F10S5G14
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 44
Duração total: 9,573
