Ir para o conteúdo principal
Sears Craftsman 315.109020 Blade/ Blade Cover Replacement
O que você precisa
  1. Sears Craftsman 315.109020 Blade/ Blade Cover Replacement, Blade/ Blade Cover: passo 1, imagem 1 %32 Sears Craftsman 315.109020 Blade/ Blade Cover Replacement, Blade/ Blade Cover: passo 1, imagem 2 %32
    • Although this is not a difficult fix, it can definitely make a mess.
    • Lay down a dirty towel or work rag and place the saw on top of the towel.
    • Handle the saw with care and avoid placing your hands on or near the blade when possible.
  2. Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: passo 2, imagem 1 %32 Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: passo 2, imagem 2 %32 Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: passo 2, imagem 3 %32
    • Use the crescent wrench to remove the hex washer head screw and the washer.
    • Gently lift the blade up and pull it off of the internal threaded shaft.
    • If the hex washer head screw, or the entire blade spins as you turn the wrench, a quick jerk of the crescent wrench should loosen the screw.
    • Although many screws loosen in the clockwise direction, the hex washer head screw on this circular saw loosens in the counter-clockwise direction.
  3. Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: passo 3, imagem 1 %32 Sears Craftsman 315.109020 Blade/ Blade Cover Replacement: passo 3, imagem 2 %32
    • Lift up on the blade cover until it unsnaps from the washer.
    • The blade cover will come off easier if the bulk of the cover is facing away from the saw.
Conclusão
Blake Avant
Membro desde: 09/29/15
218 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 17-4, Green Fall 2015 Membro de Cal Poly, Team 17-4, Green Fall 2015
CPSU-GREEN-F15S17G4
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 18
Duração total: 1,006
