Ir para o conteúdo principal
Seagate External Hard Drive drive replacement
O que você precisa
  1. Seagate External Hard Drive drive replacement, Open the housing: passo 1, imagem 1 %32 Seagate External Hard Drive drive replacement, Open the housing: passo 1, imagem 2 %32
    • It is best to open the case at the rear of the connectors.
    • The lid has plastic tabs (1) which are stuck in the base (2). They can be loosened by pushing the base outwzards with a flat screwdriver or similar tool.
    • The manufacturer did not intend for the case to be opened, so some damage to the case is to be expected. (3)
  2. Seagate External Hard Drive drive replacement, Remove the drive carriage: passo 2, imagem 1 %32 Seagate External Hard Drive drive replacement, Remove the drive carriage: passo 2, imagem 2 %32
    • The hard disk can now be lifted out of the plastic housing. It is not attached any further.
  3. Seagate External Hard Drive drive replacement, Remove the drive from the drive carriage: passo 3, imagem 1 %32 Seagate External Hard Drive drive replacement, Remove the drive from the drive carriage: passo 3, imagem 2 %32 Seagate External Hard Drive drive replacement, Remove the drive from the drive carriage: passo 3, imagem 3 %32
    • Unscrew the side screws.
    • Remove the permanently attached cables and stickers from the hard drive.
    • Then pull the hard drive backwards with a little force.
Conclusão
Repeat the steps in reverse order to reassemble your device.
Um agradecimento especial a esses tradutores:
de en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Nicola
Membro desde: 03/29/16
61 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 27
Últimos 30 dias: 105
Ao todo: 2,731
